Port interface not found using port indices. VLAN port interface states not set correctly
Validate info using 'show vlan <vlan>' command and check the ports added to the VLAN
Error
Ring port interface not found for the corresponding port index %portindex%
| Name | Type |
| portindex | uInt32 |
